Hold the Halo upright in your hand. Now, let me pee in the ring. See if that makes more HP.
http://www.halo-sparkplugs.com/why_the_halo_tip_gets_better_gas_mileage.htm <<< Same myth they should have entered in their "myths" column.
Look at the surface taken up bye the halo. That is fuel/air not displaced in that side electrode taking up less room. And if the shortest path is found with a side electrode, why would the gas slow down around the halo to keep the flame front moving. The flame now has to move all around the halo in 32 angles or whatever that patent photo shows all those pitches of curves the fuel has to fight and flame around.
It there was one side electrode, there is more fuel to start the fame front which is time is time around an object. Myths Made to justify the social science. Same with the spark waiting for the piston to be close enough to act the side electrode on the spark jump.
If that plug made more HP, you would know these are the cat's meow to use. It would be so established as a performance helper, the factory would copy the patent somehow is reverse a curve on the halo and she is a new patent of the same shot shit shot my load is spend money on one more myth.
Same myth as the 5th gear ratio of my timing retard is the retard has spoken.
* Last updated by: Hub on 7/30/2009 @ 6:01 AM *
